Hi folks,
I have create a custom action using VBScript that concatenates files installed with my setup. I have put the action after "InstallFiles" in the execute sequence of my installation. Somehow the VBScript is execute prior to the file copy.
The custom action is configured as following: "Imidiate Executing" / "Allways execute"
Can someone explain what goes wrong, where I should put the action within the sequence so that the files are copied prior to concatenate them or if I have to change anything with the configuration of my custom action.
Klaus
Action executes too early
kerber
, Jun 03 2003 13:18
Posted 03 June 2003 - 14:56
You either need to make it deferred, or put is after InstallFinalize.
