I have a custom action executable to perform regasm on all the files in the INSTALLDIR. The Executable is in the binary table, and works fine.
The custom actions table has the target field value as:
RegAsmAll "[INSTALLDIR]"
This SHOULD be the correct command line for the executable. The executable spits out a log file with the arguments and I get this:
RegAsmAll C:\Program Files\SCMFramework\"
As you will notice it has an extra Quote at the end of the second arguement. As a result my executable says it has an illeagal character in the path.
I actually tested leaving off the second quote in the target field as:
And it works! However, I don't believe it should be working this way. The quotes should bound the path to take care of the space in the path name. I've even tried adding another parameter at the end to see if it had something to do with the last character of the target field, but it still failed.
Has anyone noticed this as a problem before?
Jeff Clark
[INSTALLDIR] has extra quote
JeffPClark
, Jul 05 2004 16:25
