thanks, kris
Running cmd from a CA
kris
, Sep 24 2001 16:00
Posted 24 September 2001 - 16:00
Is there a way to hide the command window when you "run a CA to launch cmd.exe from the directory table"? I run a few commands this way, and for each I see the command window....kind of ugly to see those black boxes during the install, wondering if there's a way to supress the window?
Posted 24 September 2001 - 16:06
I doubt it, but with some clever use of a PIF file, could you not get it to appear minimized at least?
Posted 25 September 2001 - 09:13
Kris,
The solution to your problem is on this very site...
http://www.installsi...nchAppEx<p>This is the URL to the HideAppAndWait download (.rul) An InstallScript function which launches command Line arguments without the ugly box. It behaves exactly like the LaunchAppAndWait built-in InstallScript function.
Just add the definitions and code to your script and your away
Hope This Helps,
Dave.
Posted 02 October 2001 - 22:31
Thanks, Dave...I launch 2 .bat files and using this technique would get rid of those ugly command boxes. But I also launch 4 commands running a CA to launch cmd.exe from the directory table....which this wouldn't apply to.
Also, I try running this _LaunchAppEx to run my 2 .bat files and it doesn't appear to be running them......are there any known problems running .bat files with it?
kris
