multiple projects supported?
Lynn
Lynn
  • Members
  • 1 posts
Posted 28 April 2003 - 23:20
We are considering upgrading from 5.5 to 7. A year or two ago, test drove ver6 and rejected it because we allow users to install multiple versions/copies on their machines (so a user could have V7.0, V7.0EVAL, and V7.0BETA all installed). For v6, looked like I'd have to set up separate projects/guids for each release, not to mention EVAL or BETA builds (which I controlled with a simple define).
So, my question is, has this situation improved in V7? Any other big changes I should be aware of before spending days changing the script only to find out it won't work for us?
Edited by Lynn, 28 April 2003 - 23:23.
Posted 29 April 2003 - 08:03
Yes, this has greatly improved. Actually IMO this is one of the main benefits of version 7. It asks whether you want a new instance, or repair or modify the existing instance. It also handles updates nicely - shows a list of instances and asks which one to update.
There's a migration white paper (for version 5 and 6) at http://www.installsh...o/migration.asp
The release notes can be found at http://www.installsh...sp_readme70.asp
prozacrefugee
prozacrefugee
  • Members
  • 38 posts
Posted 01 May 2003 - 23:56
Does this still work if you change the GUID of the project inbetween iterations, or do you need to work out your own logic then?
Posted 02 May 2003 - 15:40
I believe the project guid must stay unchanged, but I haven't investigated this. I suggest you try it with the evaluation version.
prasankn
prasankn
  • Members
  • 22 posts
Posted 15 March 2006 - 16:48
Dear Stefan,
Can you please tell me where to get the evaluation version.
So that i can work with it before buying.
But i had done Multiple installations in ISPRO 6 using guid.exe.
I had created unique uninstallation for every installation.
But the whole thing can be done easily in ISPRO 7.
Kindly guide me how to evaluate this.
regards,
prasanna N
Posted 16 March 2006 - 19:33
The current version is InstallShield 11.5. See http://www.installsite.biz/en/ix.htm for more information and to request the evaluation download.
