File depending on OS versions
pls
pls
  • Members
  • 4 posts
Posted 08 October 2001 - 00:23
I have a case where I need to install one of two shortcuts depending on the OS version. Either way, the shortcuts need to have the same name.
The obvious way to do this is to create two components with appropriate conditions attached and put the two shortcuts in those components. The result is that neither gets installed.
How do I do this?
Posted 09 October 2001 - 15:08
Should work. Maybe a problem with the consitions you used?
