I have a dll that is self-registering. I have the 'Self Register' box checked in the properties of that file, but it will not self-register. I was using IS 6.31 and it registered fine, but after upgrading to 7, it would no longer register. I made sure that box is checked, but I don't know what else to try. Has anyone else had any problems with this?
Self-registering won't work!
jgoddard
, Dec 03 2001 17:54
Posted 03 December 2001 - 23:40
I have had a couple of problems, though not because of any upgrade.
1. My "problem" DLL required DLLs that weren't on the search path at build time. I had to either set the PATH environment variable, or add the dirs to the "App Paths" registry entry for isdev.exe. I chose the latter so I wasn't screwing up my "global" environment.
2. My other "problem" DLL is scrrun.dll, from Microsoft. If I re-register it in its "source" location, then it works fine. But it appears that something unregisters it from there (perhaps/probably my own installer) and it gets screwed up again.
