I'm sure there is a fairly straightforward solution, but how do I pre-populate controls such as list boxes in a custom dialog when using a Basic MSI?
I understand each control on the dialog can have associated events, but is there some sort of initialise event on a per-dialog basis?
Regards,
Blake.
Pre-populating combo boxes / lists
Blake Weston
, Mar 06 2003 16:37
Posted 07 March 2003 - 21:08
There is a property for the list box called Items, when this is selected it will come up with a dialog that allows you to add the items you want displayed in the list.
If you need to set your list at runtime, then you need to write a custom action that updates the ListBox table with the required information.
Anthony
Anthony
Product Availability Developer
Avantis
Invensys Process Systems
Using InstallShield Developer 7.04 - Basic Project
Avantis
