hello
I disable (not visible) features from my installation sequence in custom setup by using install script (code below). However, if i decided to go back and use original custom setup, the features are now shown.
(note that this feature includes subfeatures.)
to enable this feature again, I used same approach - except this time i tried MsiRecordSetString(hwRecord, 6, "1");
to install. but this is not working.
I even tried Addlocal and remove but the features are still visible (just not selected. that's all). MsiSetFeatureState is not working for me either.
i am totally lost here. what other option is there left??
thank you,
hDatabase = MsiGetActiveDatabase(hMSI); //get handle for database
sQuery = "SELECT * FROM Feature WHERE Feature = '"+FeatName+"'"; //find scrollable text
MsiDatabaseOpenView(hDatabase, sQuery, hwView); //open database
MsiViewExecute(hwView, 0); //execute sql command
MsiViewFetch(hwView, hwRecord); //get output
MsiViewModify(hwView, MSIMODIFY_DELETE, hwRecord); //MSIMODIFY_DELETE = 6
MsiRecordSetString(hwRecord, 6, "0"); //change value in 6th column to install level
MsiViewModify(hwView,MSIMODIFY_INSERT_TEMPORARY,hwRecord); //MSIMODIFY_INSERT_TEMPORARY = 7
//closing handles
MsiViewClose(hwView);
MsiCloseHandle(hwRecord);
MsiCloseHandle(hwView);
MsiCloseHandle(hDatabase);
enable and disable features
hsong3
, Sep 30 2003 20:07
Posted 01 October 2003 - 05:36
I don't think you can modify the msi database of the running setup in this way (e.g. deleting permanent rows). In my experience this doesn't seems to work reliably, and I don't think you're supposed to do that. All you can do is insert temporary rows.
To change the install level of a feature why don't you use the Condition table?
Posted 02 October 2003 - 08:49
Hi All,
Probably I don't know all tricks about MsiViewFetch-MSIMODIFY_DELETE
but bellow code works for me in run time (Windows 2000 SP4)
PMSIHANDLE hView = NULL;
PMSIHANDLE hRecord = NULL;
PMSIHANDLE hDB = MsiGetActiveDatabase(hInstall);
CString strSql =
_T("SELECT * FROM `ListBox` WHERE `Property`='") + strPropertyName + _T("'") ;
MsiDatabaseOpenView(hDB, strSq), &hView);
MsiViewExecute(hView, 0);
while (MsiViewFetch(hView, &hRecord)==ERROR_SUCCESS)
MsiViewModify(hView, MSIMODIFY_DELETE, hRecord);
MsiViewClose(hView);
CString strSql =
Posted 02 October 2003 - 09:09
The source with deleting and adding feature records looks OK to me, but... I don't think that changing the InstallLevel works after the Costing actions.
Try changing column 5 (Display) to hide/show the item, and MsiSetFeatureState to change the InstallState.
