[HKEY_CLASSES_ROOT\CLSID\{FDCB2348-6A5D-44B5-9115-4845F9F3F92A}\InprocServer32]
@="C:\\Program Files\\Common Files\\Adaytum\\Contributor25\\MTS\\DataProcessing25.dll"
"ThreadingModel"="Apartment"
"InprocServer32"=hex(7):4e,00,5e,00,58,00,62,00,35,00,52,00,71,00,7e,00,74,00,\
40,00,26,00,6f,00,54,00,54,00,59,00,76,00,62,00,6e,00,75,00,21,00,4d,00,54,\
00,53,00,43,00,6f,00,6d,00,70,00,6f,00,6e,00,65,00,6e,00,74,00,73,00,3e,00,\
69,00,2c,00,65,00,54,00,7a,00,24,00,59,00,70,00,57,00,3f,00,48,00,7d,00,6f,\
00,32,00,47,00,65,00,31,00,57,00,5e,00,74,00,00,00,00,00
Does anyone understand what this is for. Part of it appears to be the name of the feature with which the component was installed. They also appear for system files which were installed as part of merge modules.
If the same component is registered manually this key is not present, and it appears to be causing developers problems when they compile newer version of the components on their machines (it is still trying to use the old ones).
Martin
