I've set the value of Languages Dialog property in Release tab to yes. But the lang. setup dialog doesn't pop up. Should I set any other property besides this?
How do I enable Language Setup Dialog?
YaI
, Feb 17 2007 09:52
Posted 19 February 2007 - 06:20
Yes. In UI Languages parameter you should choose which languages your installation is provide.
Posted 26 February 2007 - 14:01
It worked only when I had set the value of setup launcher to yes. For my build output to be an msi file, do i have to set anything else??
Posted 27 February 2007 - 06:35
No, you don't. The Language Setup Dialog is a feature of bootstrapper, that InstallShield produced. MSI don't have this feature. If you want to change the language you need to use .mst-transform with command line for your package.
For more - see Platform SDK, Command Line Options topic.
Also Bootstrapping will be useful.
