I've created a dialog that asks the user for some data. The property that is associated with the edit box is called, for example, ABC. This property also has a default value that I give it in the property table when I author the setup project.
I want to create a reg value under software\myCompany\myProduct:
myKey = [ABC]
The weird thing is that no matter what value I give ABC in the dialog, it always appears in the registry with the default value that I gave it when authoring the project. Why is that? I have a feeling that the Execute sequence re-initializes all properties. If this is true, how can I avoid it?
