I'm new to Windows Installer. I use Orca to edit Msi file. Is there any way for me to detect if an application is running during install? Thank you.
Angus Lee
Detect if an application is running
anguslee
, Dec 03 2003 16:15
Posted 04 December 2003 - 08:06
You will need to create a custom action to check the process list and see if your app is running.
You can add a custom action DLL(c/c++), add it to the binary table, and then setup the custom action table with the new action.
Posted 30 December 2003 - 10:11
Hi
I came across this script some time agoe and I think this will do the trick for ya. There are of course other ways of doing this, but this is at least one way.
I've copied this script almost right as it is from the following web site:
http://www.rgagnon.c...s/wsh-0020.html
so he(they) should have all the credits.
To determine if your application is running when you are about to
install an upgrade for example you can use the script below. Well,
this is just a stub, you need to make changes in order to fit your
needs, like setting an MSI variable or poping up a dialog like I did
below.
Set WshShell = WScript.CreateObject("WScript.Shell")
Set locator = CreateObject("WbemScripting.SWbemLocator")
Set service = locator.ConnectServer()
Set props = service.ExecQuery("select name, description from
Win32_Process where name = 'program.exe'")
num = props.Count
If num > 0 Then
'Program is running
MsgBox "AFP is running!"
Else
'Program is not running
MsGBox "AFP is NOT running!"
End If
Set WSHShell = Nothing
Tobias
below.
num = props.Count
If num > 0 Then
'Program is running
Else
End If
Tobias
