Hi to everybody
i would like my installer to have the following behaviour:
if (legacy application found){
replace_existing_files_with_new_ones
(keeping the same directory structure)
else{
clean_msi_installation
How can i give this direction to windows installer? What changes must be made in the InstallExecuteSequence table?
thanks,
Nestoras
Directing the installation procedure
nestoras
, Dec 13 2004 14:11
Posted 14 December 2004 - 09:49
You need to detect the existing directory structure e.g. using AppSearch, and then insert custom actions of type set-a-directory to change the destination directories of your components. You need to specify diffferent directory identifiers for your components if you want to move them around independently.
