I'm trying to fill a combobox in a custom dialog in IS7.0 standard project using the CtrlSetList function accoording to the help file. However it seems this function works correctly since the result value is 0, but it does not list the items in the combobox!! If I use the same function with a listbox it does display all the items!
How can I get it to work for a combo box? Or is there a workaround?
tnx
