Language problem
Posted 27 November 2001 - 15:41
Posted 27 November 2001 - 19:49
(Edited by lasenbby at 11:23 pm on Nov. 27, 2001)
Posted 27 November 2001 - 21:19
Posted 04 December 2001 - 23:54
Becky
Posted 05 December 2001 - 06:44
I am trying a English NT installation package on Chinese Winnt 4.0 version Service pack 6.
I have been trying to install all the files I install in the application target directory so that I don't touch system directory at all of chinese NT OS. Will this work ?
Also I would be happy if could clarify my queries?
a) I am trying to install the files in OLEDB installshield object individually in application target directory instead of using installshield object?
Are there any problems regarding this type of installation?
b) Will third party ocx files built in windows NT English work in Chinese NT?
c) Are the JET 4.0 , OLEDB and MDAC packages from Microsoft language dependant?
thanks,
Senthill
| Quote |
| Quote: from lasenbby on 6:49 pm on Nov. 27, 2001 Should work unless they don't have a specific os, sp or IE version. Ensure your custom dll(s) use the system font (or whatever font IS uses for eng in its isres.dll or the jpn os may not have it). Also, if your install relies on third party products, they may not be compliant.
Posted 05 December 2001 - 20:52
a) Should be able to do it fine as long as you know what you are doing with the technology and install all the files required and register them correctly. (Personally, I prefer not to use IS objects because they have support for ALL languages and tend to be large and build time is forever and so I place the files myself. If you don't understand the technology, I can see a use for them.)
b) Have to check with the third party doc. If you build the ocxs, you may have to add:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\CodePage
value: 932
data: c_932.nls
(I think...you may need to do a little research on the correct codepage.)
c) Don't know off the top of my head but you can get on MS' website and find out for each technology.
Posted 05 December 2001 - 23:15
Posted 06 December 2001 - 06:21
