i have many problems to use object "SdFeatureDialog" because i'm not able to know the exacts steps for use it.
I want that user could select 3 option in dialog and install different feature for every option.
An example:
- Option 1
- Option 2
- Option 3
If i select "Option 1" i want install feature called "FeatureOpt1", elseif i select "Option 2" i want install feature called "FeatureOpt2", elseif i select "Option 3" i want install feature called "FeatureOpt3".
This is my wrong code:
Correct steps for use "SdFeatureDialog"
mkuggsrock
, Dec 02 2009 19:01
Posted 02 December 2009 - 19:01
| function ShowProgramsOptions(szTitle, szMsg, svResultPrograms, nStyle) LIST listPrograms; BOOL bSelected; STRING svSelected, svSelectedSel, szMedia, szComponent; STRING svFeatureName; NUMBER nDataSize, nResult; STRING szData; NUMBER nInfo, nData; STRING svResult(); NUMBER count; begin szMedia = "myMedia"; nDataSize = 0; bSelected = FALSE; listPrograms = ListCreate(STRINGLIST); MEDIA = szMedia; // Set options FeatureAddItem(szMedia, "Option1", nDataSize, 1); FeatureAddItem(szMedia, "Option2", nDataSize, 1); FeatureAddItem(szMedia, "Option3", nDataSize, 1); // Show dialog SdFeatureDialog (szTitle, szMsg, INSTALLDIR, ""); // Set selected option FeatureListItems(MEDIA, "", listPrograms); nResult = ListGetFirstString(listPrograms, svSelected); // For every selected item i install relative feature while (nResult != END_OF_LIST) if (FeatureIsItemSelected(MEDIA, "FeatureOpt1")) then FeatureGetData(MEDIA, svSelected, FEATURE_FIELD_MISC, nResult, svFeatureName); endif; endif; nResult = ListGetNextString(listPrograms, svSelected); endwhile; ListDestroy(listPrograms); MEDIA = "DATA"; // Ripristino il media originale. return 0; end; |
Please could you help me?
What are the sequential steps for a corret use of these objects?
In example:
FeatureAddItem -> SdFeatureDialog -> FeatureListItems -> FeatureIsItemSelected -> FeatureGetData -> etc......
Many thanks for every answer and help.
Mark
Posted 03 December 2009 - 08:20
The easiest way might be to use the real features in the dialog, instead of a script created fewature set. However if you need to use the script created features you need to get their selection state (FeatureIsItemSelected) and then select the real features based on that (FeatureSelectItem)
Posted 03 December 2009 - 08:46
Sorry for my ignorance, but...how can i use the real feature in the dialog??
Thanks for help, but it's the first time that i use this dialog...
Posted 03 December 2009 - 11:51
Probably it functions now, it's difficult for me...but interesting
Many thanks Stefan
Many thanks Stefan
Posted 03 December 2009 - 17:57
| how can i use the real feature in the dialog?? |
You simply don't change the value of MEDIA, and remove all the other stuff:
function ShowProgramsOptions(szTitle, szMsg, svResultPrograms, nStyle) begin SdFeatureDialog (szTitle, szMsg, INSTALLDIR, ""); return 0; end; |
Posted 04 December 2009 - 07:48
Hi Stefan,
yes, it function very well, it's more simply than script
It's interesting learn new features of this software.
Thanks for help, have a good week-end!
Mark
Mark
