Now, the problem is solved if the installation is done using an MSI file, but from a Setup.exe file, the system copies the MSI in a temporary directory and it executes the install process from there. Concequently, the SRCDIR point to that temporary directory.
Is there any way one can get the initial directory (the one where Setup.exe resides in)?
Thanks a lot,
Jean
