The patch I've created has been successfully applied to over 10 customers' installations, but one particular customer is getting an error message applying the patch. Here is the error:
Internal Error 2709.
CopyData_Extract_at_Build.68DD5CDA_E595_11D4_8
B3C_00C04F60AA59
Any ideas what the problem could be, or what could be causing it?
Ryan H.
Customer getting error applying patch
ryan h
, Jul 11 2002 15:22
Posted 23 July 2002 - 15:29
according to the MSI help files this error is "the specified Componwent name not found in Component Table".
was this component added in by a merge module ? did the merge module pass the merge ICE tests ? are the systems based on the same build ? could you describe the process used in more detail ?
sorry for more asking questions then providing answers....
