I want to "convert" from a CVS-controlled isv project to a ism project, to do some string processing and to build the project.
On a standalone buildmachine the call to ImportProject failed.
Here is a code snippet to convert the project (VB-script)
Automation Interface: ImportProject method failed
homer
, Sep 27 2004 08:29
Posted 27 September 2004 - 08:29
Dim ISWIProject Dim ism_file Dim isv_file ism_file = "C:\some_ism.ism" isv_file = "C:\some_isv.isv" Set ISWIProject = CreateObject("SAAuto8SP1.ISWiProject") if Not IsObject(ISWIProject) then Set ISWIProject = CreateObject("ISWiAutomation.ISWiProject"): CheckError end if ISWIProject.ImportProject ism_file, isv_file : CheckError Sub CheckError() Dim message, errRec If Err = 0 Then Exit Sub message = Err.Source & " " & Hex(Err) & ": " & Err.Description Wscript.Echo message Wscript.Quit -1 End Sub |
It gives an error like: ..\script.vbs(32, 5) SAAuto8SP1: Resource with identifier '103' not found
Where Line 32 is the call to ISWIProject.ImportProject.
If i call the same VB-script on my developer machine (IS-Developer 8 SP1 german) it works fine.
Whate is going wrong here?
Please help me.
Daniel
Original Post on InstallShield community: http://community.ins...ad.php?t=139305
Posted 27 September 2004 - 12:57
I solved the Problem.
I did a Reboot of the System end it works.
THANK YOU INSTALLSHIELD
Posted 28 September 2004 - 09:49
The problem was not the reboot.
The ImportProject method, couldn't handle '/' forward slashes in a path.
After replace all '/' to '\' back slashes, it worked.
Posted 28 September 2004 - 09:50
OK, but never underestimate the power of the magic reboot! That is Windows for you...
