If I only want to execute a custom action at first installation of a product I use
NOT Installed as a condition in the script.
and if I want to do it at first installation and removal of the product I can write
(( NOT Installed ) OR ( REMOVE~="ALL" ))
But how do i write a condition for the case where I want to execute the CA at first install and at upgrade ?
BR Ulf
How do I enable CA only at upgrade?
uljo2
, Sep 29 2008 13:53
Posted 30 September 2008 - 09:49
Now I know.
Use the ActionProperty from the Ugrade table. In my installation it is called.
UPGRADE_1
It's either null or contains the upgrade GUID if it has been detected.
((NOT Installed) OR (UPGRADE_1))
/Ulf
Now I know.
UPGRADE_1
/Ulf
Posted 01 October 2008 - 09:52
There is also the built in UPGRADINGPRODUCTCODE property.
The most common property checks:
* REMOVE = ALL
* Installed
* UPGRADINGPRODUCTCODE
Just from memory (correct me if I am wrong guys, I haven't run testing on this - just want you to have a list to look at in case you need a different condition):
* (REMOVE = ALL) is true for uninstall.
* (Not Installed) is true for a fresh install or a major upgrade.
* (Not Installed) AND (NOT UPGRADINGPRODUCTCODE) is true for a fresh install.
* (Installed) AND (NOT REMOVE = ALL) indicates a minor upgrade or (self)repair.
* REMOVE = ALL
* Installed
Posted 04 October 2008 - 15:47
UPGRADINGPRODUCTCODE will be set during a Major Upgrade but in the old version which is being removed. It's not set in the new version which is being installed.
