I am using the following condition to test if the user is trying to install into the root drive or into Windows or Windows\System. This was working when the user browsed for the folder, but now they typed in the folder c:\windows in the edit field.
(INSTALLDIR=WindowsVolume Or INSTALLDIR><WindowsFolder)
It appears the above check is case-sensitive. Is there anyway of making this check case-insensitive or could you make another suggestion on how to prevent the user from installing into specific folders?
-Shawn
Case-sensitivity when using ><
smc0862
, Feb 07 2005 23:01
