This is simple stuff I have used before.
In "Custom Setup", user deselect a feature.
Depending upon whether &FeatureName <> 3 (not selected), the next button will causes to goto dialog A.
However, this is not working!
I put another condition on the next button, if &FeatureName = 3, then goto dialog B.
User deselects the feature (red X) but it still goes to B. So even when feature is deselected, &FeatureNme=3 evaluates TRUE!
I have this working in another installer. Any clue what is going on??? I have looked thru the feature properties and cannot see a discrepancy.
When I deselect feature is STILL selected!!!
cmahood
, Aug 05 2004 22:03
Posted 06 August 2004 - 04:31
Did you check the value of FeatureName once you end up with dialog B? It could be that it is a refresh issue and that the property maintains its value until you click the next button and then is updated. This is a classic windows installer dialog problem.
