I have placed a Dll in the Binary table and have streamed it out successfully with the StreamFileFromBinary function in the Onbegin event handler.
I have a CA of type 132096 which calls a function in the dll which IS in the temp directory as expected. The deferred CA fails with "Failed to extract file 'x.dll' from binary table.
The dll contains sensitive content so installing it with the rest of the files then deleting it is not feasible.
Any ideas how to call a function in a dll streamed from the binary table. The dll dependancies are correct as the same set of files where used in Setup Files in an InstallShield 5.5 Installation.
Thank you in advance.
