I build a setup,
compose of 30 components, to install a component, the user introduce a key code and the code give a condition to install the component.
So I have a dialog that receive the keycode and the button next fill a property MAP with all component to install
ie : code = ABC -DEF - IJK
MAP = componantA componantB componantC.
it work perfectly
after the installation if I want to add componantD
the code is ABC -DEF - IJK - LMN
So when i launch the setup a second time and choose modify
The dialog never appear.
instead I have the list of all component but I can install them.
If I click on the previous button, I have an error 2803 no dialog.
It is logic because I definied no dialog procedure.
My question is simple : How to call some dialog and action of the installation procedure to the modify procedure.
Edited by pavlacki, 04 April 2005 - 15:59.
