I want to create a database from command promt during installation (Using isql / osql ). Could anyone help me on this. It would be of great help if any one can help with some examples.
Shajil
How to create a database from Command prompt
shajilr
, Oct 15 2002 12:59
Posted 15 October 2002 - 15:16
well I use a multi-tier step to accomplish this. First I use the script to create the directories. Then I call a batch file:
The batch file I call follows:
and then my sql scripts:
Hope this helps. Some of it is pretty specific to what I do, but it should give you an idea.
A caveat: Since I only install or Server software on systems we design, I already know what the drive scheme looks like. You'll probably need to be a littel more deterministic.
| Code Sample |
/////////////////////////////////////////////////////////////////////////////// // // FUNCTION: CreateDatabase(): // // PURPOSE: This function will setup the database and log files // for Digital and Analog Server setup. /////////////////////////////////////////////////////////////////////////////// function CreateDatabase() STRING szPath, Adb, Ddb, szMsg, szMsg1; NUMBER DVD, nvExitCode, nExit,nSize; begin // Create MyDB database .mdf & .ldf files// szPath = "E:\\MyDB"; if ExistsDir(szPath) < 0 then CreateDir(szPath); if (CreateDir(szPath) < 0) then MessageBox("E:\MyDB, directory was not created successfully.", SEVERE); abort; endif; endif; szPath = "D:\\MyDB"; if ExistsDir (szPath) < 0 then CreateDir (szPath); if (CreateDir (szPath) < 0) then MessageBox ("D:\MyDB, directory was not created successfully.", SEVERE); abort; endif; endif; VarSave(SRCTARGETDIR); TARGETDIR = TARGETDIR + "\\ProductName Database"; ChangeDirectory (TARGETDIR); // It is necessary to do a change directory before launch. if(bIsWindows2000=TRUE) then SdShowMsg("Creating and modifying MyDB database.", TRUE); Enable(HOURGLASS); _LaunchAppEx(TARGETDIR + "\\CreateDatabase.bat", "", WAIT,SW_HIDE,-1,nExit); SdShowMsg("Creating and modifying MyDB database.", FALSE); Disable(HOURGLASS); else SdShowMsg("Creating and modifying MyDB database.", TRUE); Enable(HOURGLASS); LaunchAppAndWait(TARGETDIR + "\\CreateDatabase.bat", "", WAIT); SdShowMsg("Creating and modifying MyDB database.", FALSE); Disable(HOURGLASS); endif; VarRestore (SRCTARGETDIR); endif; |
| Code Sample |
| echo off echo Creating MyDB database... isql -E -n -i CreateMyDB.sql echo Creating jobs... isql -E -n -i CreateJobs.sql echo Adding tables and stored procedures... echo off isql -E -n -m 20 -d MyDB -i ScriptName.sql echo Adding domain data... echo off isql -E -n -m 20 -d MyDB -i InsertDomainRecords.sql echo Finished creating MyDB database! |
| Code Sample |
| create database MyDB on (name = 'MyDB', filename = 'e:\ProductName\MyDB.mdf', size = 50, maxsize = 5500, filegrowth = 10) log on (name = 'MyDBLog', filename = 'd:\ProductName\MyDB.ldf', size = 500, filegrowth = 10) go /* Set some database options */ exec sp_dboption 'MyDB', 'autoshrink', 'FALSE' exec sp_dboption 'MyDB', 'trunc. log on chkpt.', 'FALSE' |
