Hello,
We're using a Developer 7.02 Standard project. In our first release, the install creates several entries in an INI file. The entries are created conditionally based on which features the user has installed. The entries are created via script in the 'Feature_Installed' events. Our second release requires us to use the major upgrade approach and it all appears to work correctly, with one exception - the INI entries are removed at the end of the setup.
The INI entries are required for backward compatibility with other systems we have released, so we can't simply replace them with corresponding registry entries. We have tried all kinds of approaches and the result is always the same. InstallShield support says it should work as is, but so far, no luck. I'm sure there must be some simple thing I've overlooked. Any suggestions would be greatly appreciated.
Major Upgrade Removes INI Entries
mcollins
, Mar 16 2002 23:22
