I've got problem to build MSI setup with standalone 2012 installation (IsCmdBld.exe) on Win XP 32 bit machine.
The setup ended with the following errors:
ISDEV : error -6258: An error occurred extracting digital signature information from file <MSI File>. Make sure the digital signature information provided in the IDE is correct.
ISDEV : error -6003: An error occurred streaming '<MSI File>' into setup.exe
The same setup, was successfully built on my local machine (Win 7 64bit) with basic MSI 2012 premier installation!
I found that signcode.exe and SignTool.exe files are equal between the machines.
Do you know what is the problem?
Please advice.
Many thanks.
