I am trying to register COM Interop dlls using Installshield from last 10 days but still found no luck. Here's the issue:
I have an Installscript project with some ActiveX controls and dlls. Now I want to replace some ActiveX with .NET com Interop dlls created on VS2010 using C#.net. I am registering those com Interop dlls using batch file.
I tried the same stuff using Basic MSI also but it didn't worked.
So the Issue is , If VS2010 is installed on the client machine then application works properly but If .NET Framework is Installed on the client machine instead of VS2010 , dlls get registered but application doesn't work and throws an error "Make sure the Object is entered in the system registry". Any idea on what I am doing wrong? Thanks in advance.
InstallShield "Basic MSI" Projects
viveksoni
, Mar 11 2013 11:11
