Hello All,
I have a strange problem. I have a setup which has some files stored in the Disk1. However I want to have the flexibility of a single, self-extracting executable as well. Though I can build the setup to go into a single self-extracting executable, I have problems locating the files that I stored in Disk1.
Here are the details:
The files stored in Disk1 are a set of files (including two folders) that I need to call from within the installation. Since they have folders, I cannot put them in the Support Files section. So I had to choose Disk1. When I build the setup and I go to the Disk1 folder and run the Setup.exe from there, I can very well access these files. However when I run the single self-extracting executable, the script cannot access these files.
I could only get information about the PACKAGE_LOCATION which returns the location from where the single executable was run. However I cannot find out how I can use it to work out the path to my desired files.
Here's the folder hierarchy on Disk1:
MainFolder1
---- setup.exe
---- setup.ini
---- Folder1
---- Folder2
From within the script, when in Disk mode, I can easily use "MainFolder1\\Setup.exe" to call the file. However from within the single executable, I cannot seem to find the correct location where the files have been extracted.
Any help would be greatly appreciated.
URGENT: Disk1 contents from single exe
honeybee
, Feb 17 2006 13:30
Posted 18 February 2006 - 10:22
I think your setup.exe etc. including all your Disk1 files will get extracted to a subfolder of the TEMP folder. That location is stored in SRCDIR.
