I use Install Shield 12 SP2. Thanks and sorry for my english
Minor upgrade issue
necrostaz
, Jan 27 2009 11:49
Posted 27 January 2009 - 11:49
Hi all ! I need to upgrade some assemblies in GAC from old versions to new by minor upgrade. I have add .Net assembly to each component which contains key file with assemby .dll and specify strong name (Name,Version and PublicKeyToken) for each. With minor upgrade i have change only version field of assembly. After upgrade installs new assembly version appears in GAC, but old remains. Ok. Let it be. But when i tried to uninstall, new versions successfully deleted, but old remains in GAC. How i can remove old versions during uninstall proccess ?
Posted 30 January 2009 - 15:08
I was found solution, but it's not optimal in my opinion. For each new assembly i create new component and set Condition=0 for corresponding old component. But may be alternate solution exist ? Thanx.
Edited by necrostaz, 30 January 2009 - 15:08.
Posted 06 April 2009 - 10:44
Set condition=0 for a component makes that component not installed. As you are giving 0 to the old component and this will not come in GAC. Now only new component will present in GAC.
