Hi All,
I have Visaul Studio .NET Enterprise Developer 2003. There is an MSI (vs_setup.msi) for this but I can't run this directly. I get a message: "To install this product please run setup.exe".
I would like to use the MSI to install this product. Is there any possibilty for this?
I found out that there are 2 custom action inside the MSI that ask me to run the setup.exe. If I changed the conditions of these custom action (or if I deleted these custom actions) I could install the app with the MSI but after some attempt to install I always realized that everything fine except the main EXE so I can't launch the "Visual Studio .NET 2003" shortcut (I tried directly the exe also).
It seemed to start but after that its window was closed. There is no error or warning entry in the EventView. Installation log file is OK. Tried to repair the application but this did't work either. It seemed that the installation started as if the app wouldn't have been installed at all.
If I can't avoid to use the setup.exe is there any possibility to run the setup.exe in silent mode?
I tried to use the switches below:
- /q
- /qn
- /qr
- /settings myinifile.ini
I experienced that I can launch the setup.exe with any switch but they don't take effect and the installation run as without switches or I can't launch the exe at all.
Any idea?
Run VS.NET silently
Magic
, Dec 05 2005 14:54
Posted 19 January 2006 - 18:54
I think the Setup executables use different switches. Try "/passive"...
If you're a developer, there has to be a way to divine what switches/registry magic that Setup is doing, in order to reproduce it. I'd imagine it's passing a property of some kind...
Posted 20 January 2006 - 17:06
