I am trying to start a new installation, and use areas of IS 6 that i have not used before, i have added in Component Functions a function that i wont to call when the component is installed. The problem is that the function is not being called and i do not understand why. The function is in a seperate .rul file but i have referenced the .rul file in the main setup.rul. Has anybody any thoughts on what i have done wrong?
Component Functions
Darren Forsdike
, Jan 30 2002 15:56
Posted 31 January 2002 - 17:12
in which way did you include the .rul file?
what kind of error did you retrieve?
bye- 2k1_experience
Posted 31 January 2002 - 17:30
Unfortunatly i have not recieved any error the function within the rul file just does not get called, although i have referenced the function in component functions oninstalled event.
I referenced the rul file by putting
#include "qsaupdate.rul"
at the end of the rul file
Darren
Posted 01 February 2002 - 14:21
ok, but didn't you forger a .h file at the beginning of the main setup.rul script?
if not sincerely i don't know...i'm not a master in installshield...but if you have question you're welcome..
2k1
Posted 12 February 2002 - 00:52
At the risk of oversimplifying, Did you add the function name to be called at the component level?
I.e. On the component tab, hi-light the desired component and then at the botom of the property-value pane, add your function name... It should work then...
