Hello everyone,
I have a fairly complex IS2008 project which installs 3 websites that use dotnet framework 1.1. These 3 websites are using an Application Pool that is also created by the installer.
Problem is that I cannot find a way to set the 1.1 framework for the newly created AppPool... In older versions of IIS (6.0) there was no such setting at AppPool level... So IS2008 doesn't have an option to set the framework version for Application Pools...
Any Idea?
TIA
spaolo
Application pool in IIS 7.0 Server 2008
spaolobitech
, Jul 09 2008 14:34
Posted 27 November 2008 - 16:22
| QUOTE (spaolobitech @ 2008-07-09 13:34) |
| Hello everyone, I have a fairly complex IS2008 project which installs 3 websites that use dotnet framework 1.1. These 3 websites are using an Application Pool that is also created by the installer. Problem is that I cannot find a way to set the 1.1 framework for the newly created AppPool... In older versions of IIS (6.0) there was no such setting at AppPool level... So IS2008 doesn't have an option to set the framework version for Application Pools... Any Idea? TIA spaolo |
For your infor this does not work in IS2009 either. IS simply does not support IIS although they say they do. You need to do this with a custom actions calling using appcmd or similar.
