Hi all,
I had something that appears weird happen while testing a Custom Action widget. I pass in a /r or a /u with either being followed by [INSTALLDIR].
I noticed that I needed "" when I discovered that INSTALLDIR was coming in as C:\Program instead of C:\Program Files\MyFolder. However, after passing the parameter as "[INSTALLDIR]", my widget received and displayed it as C:\Program Files\MyFolder". There was an ending ", but none at the beginning (I would expect none.).
I then passed the parameter as "[INSTALLDIR] with no following " and all appeared to function as expected then in the widget.
Does the leading " signify a path with spaces included?
If any information is needed, the widget is basically a .NET v4 targeted VB.NET app that registers some 64 bit files with Framework64's RegAsm.
I guess my parameter will be passed as "[INSTALLDIR] as that seems to work for now.
Thanks for any help!
Custom Action Parameter using "" ...
Superfreak3
, Jan 20 2011 04:05
Posted 20 January 2011 - 18:57
I don't think that Windows Installer is doing anything special with " signs. But maybe VB.NET does some pre-processing?
