The main problem i am facing is to hide the check box & the corresponding text in the Setupcompletedialog for a particular release.
I tried setting a property & a condition for the checkbox in the setupcompletedialog. but it doesnt seem to be working.
Is their any other alternative to resolve the issue??
Please help me out.
Hide Check box
sahana
, Nov 10 2008 10:43
Posted 11 November 2008 - 07:08
Which project are you using? Basic or Installscript MSI?
What have you tried?
-vijay
-vijay
Posted 12 November 2008 - 01:24
This should work. You should be able to show/hide, enable/disable controls.
Are you sure the condition and the control name is correct?
Try setting the condition to 1. If you have multiple condition entries in the table, set them all to one for say "hide" for that control.
If that works, then your conditioning is the problem.
Also a quick tip - test your conditioning (if possible) on the InstallWelcome dialog. This saves you running to the end of the installation each time you have to test this.
