is there such a thing as an uninstall log? if so... how to do you get one?
i have an install log automatically generated but when i uninstall there aren't any uninstall statements generated.
uninstall log?
dtasanas
, Jan 17 2005 23:18
Posted 18 January 2005 - 09:27
Windows Installer doesn't create any log files unless you tell it to. You can run the uninstall with the same lagging command line parameters as the install. or you enable MSI logging globally using the registry. For details see http://www.msifaq.com/a/1022.htm
