I am trying to follow what says in the Installshield Developer 7.03 manual regarding the patches and when I follow the release wizard althought I have checked the uncompressed files both old and new confoguration I cannot check or uncheck the "Create installation launcher".
Is this a problem with installshield?
When I create the patch even without the above mentioned option checked by default when I run it on the target machine I get the patch to run till the end without doing any changes to the first installed product.
I also tried this same thing to another project and I get error without being able to install the patch.
Can anybody help me out with this problem?
PS. I have created a second product configuration to the original setup project through the InstallShield environment and I have changed the product code and rest things that I am supposed to.
Preparing for Patch
yiannis
, Jun 19 2002 23:42
Posted 21 June 2002 - 17:41
This is a know issue with developer. Goto http://support.installshield.com/kb and search for it. They will give you a workaround for the problem.
