Here's my current problem.
I have one install package, that I make 6 different builds with depending on the version I specify at the beginning.
the field is APP_TYPE.
Now, for each build, I have a different 'Main' component for each, which I enbale/disable by checking the APP_TYPE and use
ComponentSetData (MEDIA, "Base System AAA", COMPONENT_FIELD_SELECTED, FALSE, "");
One of my components doesn't include a DAO file group. However, when installing, the DAO group gets installed. Also, I have a shortcut that gets created on the desktop for all versions but one. So I associated the shortcut to a File Group that is not a part of this Component. but again, it gets installed.
It's as if it was ignoring what I've selected within the component. Any ideas?
SC
Components not using right file groups.
SilentCry
, Apr 26 2002 15:05
Posted 27 April 2002 - 03:35
Humm, that's an odd one, but have some basic suggestions.
Have you confirmed you're getting a valid result code of zero? 'cause otherwise you have a ComponentError.
Also, have you tried using the simpler ComponentSelectItem function instead? The call would go something like this:
ComponentSelectItem (MEDIA, "Base System AAA", FALSE);
Finally, what does ComponentIsItemSelected return about this guy? Does it confirm that your previous action was properly applied?
