Display filenames on Progress dialog?
Posted 21 September 2001 - 23:57
Posted 22 September 2001 - 00:30
Add an entry to the EventMapping table with an ActionData event linked to a Text control.
Posted 26 September 2001 - 01:45
could you be little bit more specific? did you use orca to modify the .msi file manually? if not, how do I add an entry to the EventMapping table. An example will be very helpful. Thank you in advance for your help.
Posted 26 September 2001 - 20:13
1) Control table - add a Text control called ActionData to your SetupProgress dialog.
2) EventMapping table - add an entry:
Dialog_ SetupProgress
Control_ ActionData
Event ActionData
Attribute Text
3) ActionText table - add an entry:
Action InstallFiles
Description Installing files
Template File: [1]
The variable [1] displays just the filename, you can use [9][1] to display the entire target path and filename.
The Description in the ActionText table can be displayed by linking a Text control to an ActionText event in the EventMapping table.
Hope this helps!
Posted 28 September 2001 - 23:20
For each build, i have to use Orca to change the .msi file manually. Is there a way I can avoid that? thanks.
Posted 29 September 2001 - 13:37
Posted 01 October 2001 - 15:23
