I am trying to create an InstallShied Express setup that will replace 5 registered DLLs with the new versions included in the setup, and then register the new ones. My testing shows that the old DLLs are not being unregistered. I do have the "Allow express to self-register this file" option set.
Thanks.
Unregister/reregister DLL with InstallShied expres
erosenbaum
, Mar 20 2009 18:04
Posted 27 March 2009 - 10:17
Did you specify the old setup in the Previous Versions section? (This should internally create a Major Upgrade that would remove the old version and then install the new version).
Posted 08 April 2016 - 17:35
I'm having a similar issue--How do you "specify the old setup in the Previous Versions section"? I'm using InstallShield LE 2013.
Thanks!
Posted 12 April 2016 - 09:03
This article describes the steps with screenshots: http://syncor.blogsp...lshield-le.html
