Hi eevryone,
I am creating a setup that has Flash Player as its dependency.
I want to check if the flash player is installed on the system? If its installed then what version is installed?
Can some one has got any ides about this?? Any registry key?? some file?? some other way ??
cHeers,
ankur
Finding Flash
antyagi
, Sep 19 2006 12:22
Posted 19 September 2006 - 16:00
In enterprise environments set the dependencies with your software-deployment-tool. Otherwise you can set LaunchConditions directly in the MSI:
LaunchCondition
LaunchCondition
Condition Description --------------------------------------------------------------- FLASH8 OR FLASH7 OR FLASH6 Install Flashplayer first! |
(expand the Properties for more versions to FLASH5, 4, etc.)
AppSearch
Property Signature_ ------------------------ FLASH8 SigFlash8 FLASH7 SigFlash7 FLASH6 SigFlash6 |
RegLocator
Signature Root Key Name Type ------------------------------------------------------------------- SigFlash6 0 ShockwaveFlash.ShockwaveFlash.6 2 SigFlash5 0 ShockwaveFlash.ShockwaveFlash.5 2 SigFlash4 0 ShockwaveFlash.ShockwaveFlash.4 2 |
Keep in mind to move the Action LaunchConditions in InstallUISequence & InstallExecuteSequence after AppSearch Action! (In InstallShield this is necessary too!)
The corresponding Registry-Keys are:
HKCR\ShockwaveFlash.ShockwaveFlash.6
HKCR\ShockwaveFlash.ShockwaveFlash.5
HKCR\ShockwaveFlash.ShockwaveFlash.4
Dominik Oberlin
Edited by Dominik Oberlin, 19 September 2006 - 17:09.
Posted 20 September 2006 - 13:20
I am looking for Flash Player 9. And the Flash Player 9 setup available with me is not creating any registry entry looking like ShockwaveFlash.ShockwaveFlash.9.
Registry entries from ShockwaveFlash.ShockwaveFlash.1 to ShockwaveFlash.ShockwaveFlash.1 are already there on fresh installed WinXP machine.
By-the-way, Is there any difference between Flash Player and Flash Plugin?
The setup I have says it is installing Flash Player, but actually it is looking for browser's plugin folder to install Flash Plugin
ankur tyagi
