I have Installshield 10.5.
I cannot install the msi on vista when UAC is turned on.
I cannot turn it off.
So how should I able to achieve this?I understand that which UAC om msi needs elevated execution privilage in order to run successfully.When I cannot do this directly, I have to run it from an elevated command prompt , which is not an acceptible solution for our customers.
So is there a way we can achieve this. From the forums I got the hint that this can be done by properly authoring the msm, in the sense it may have an iplication on the custom action.
If anyone can come with a good solution it shall be highly appreciated.
Sudarshan
Edited by sudarshan123, 07 February 2008 - 23:08.
