hello
I am trying to create a new environment variable during my setup.
so i add a new variable SSBB, then change settings like
Component - files
Value - [INSTALLDIR]bin
On install - Set
Placement - Replace
On Uninstall - Remove
Type - System
then i check my Direct Editor
NewEnvironment2 *=-SSBB [INSTALLDIR]bin files
however after installation, my setup creates the new envirnment under Administrator (user); not under System.
also, name of this environment is not what i set above. it suppose to be SSBB, but after installation, it is either "NewEnvironment2" or "Name"
is this known issue in installshield 7??
or is there something missing in my setup??
thank you
can not create environment variable
hsong3
, Jan 28 2004 22:51
