Redistributables - Merge Modules
Posted 22 April 2015 - 15:57
Posted 22 April 2015 - 16:16
I would recommend not deleting files in system folders. Many microsoft dlls can live on the system at the same time, MS XML included. If you need to upgrade to a newer version, simply ship your new version with the correct merge module and leave the old version alone.
Posted 22 April 2015 - 18:42
Hi deramor,
I agree with you but I can't build a new install until next delivery (customer request).
I need to find a solution to remove msxml4 without impacting our application.
M
Posted 22 April 2015 - 20:41
Can't you just use the MSXML 6.0 redistributable in the place of whatever process you are having the customer do to delete the old 4.0 version?
http://www.microsoft...ls.aspx?id=3988
Posted 23 April 2015 - 18:12
Absolutely agree with you but they don't want it that way. No idea why. ^^
Anyway, if I delete the msxml4, the repair option dialog come up when I tried to launch our application.
Something is associated between msxml4 and our application but I'm not sure how to dissociate.
Thanks.
Edited by maxk, 23 April 2015 - 18:12.
