after repairing the application Desktop shortcut is not coming.I verified MSI all components are having Keypath.Pls help me in this regard
Desktop shortcut is not repairing
roopesha2
, Sep 04 2007 11:14
Posted 05 September 2007 - 11:27
If the component isn't broken (missing or corrupted keypath) then the shortcut will not get repaired.
If you want to make sure the desktop shortcut is always in place then place it under "All Users" or create a desktop extension shortcut instead. If it's not a lockdown environment any normal user with higher filesystem permission could simply delete the shortcut which would prevent the shortcut from being repaired. Using a desktop extension instead of a regular shortcut would probable be repaired if it is deleted by the user.
Edited by AngelD, 05 September 2007 - 11:28.
