In my installation I have a set of features that must be installed mutually exclusive on the target system.
Being a good practice (and after an inquiry perhaps being one of the few reasonable alternatives) in this case I have authored a new dialog which uses RadioButtons to ensure exclusiveness at the UI level. Then the features can be mutually selected with AddLocal and Remove ControlEvents of a PushButton.
But how can mutual exclusiveness be guaranteed if the Installer does not run at full UI level and the dialog will not be shown?
How do I ensure an initial selection of certain features based on a property? (as I have understood standard/custom actions to do this are not available and that e.g. MsiUseFeature functions are not allowed...)
To complicate matters further, the underlying components use identical file names (that's also a reason why they must be mutual exclusive) and I don't know how this does interfere with windows installer. I want that maintainance and repair installations work properly...
(If the feature selection state is based on a local property, would I have to save the property then? (so that repair and maintainance installations will work properly either in full UI mode or not?))
Another very nice thing was that with this approach I could use two orthogonal parameters, i.e. I could use feature-states and then the component-conditions to select of the remaining features/components, which I think (?) is not possible when only using features and subfeatures. e.g. for a language selection task for 2 features A and B one would have to include the subfeatures A_english and B_english, compared to the 2 independent selections feature A and condition "english"...]
Thank you very much in advance!
