InstallAware Software Corporation announced the release of Setup Squeezer, an application to recompress Windows Installer (MSI) and InstallShield (EXE) setups using the most advanced algorithms available today. With LZMA compression technology, and BCJ2 compression pre-processing, Setup Squeezer is able to make already-compressed setups smaller by an additional 15% to 50%. For instance, Setup Squeezer for Windows Installer reduces Microsoft’s Windows Defender MSI setup down to 3.2MB from 6.5MB.
Setup Squeezer improves on existing setup-compression tools by offering a very simple wizard interface that helps you intelligently unpack and repackage existing setups, with runtime support for all versions of Windows from Windows 95 to Windows Vista, using an extraction process that the user can abort, while running with as little as 32MB of physical memory. Previously compressed packages and nested setups are recursively scanned, opened, and automatically recompressed.
Setup Squeezer is available in two versions — Setup Squeezer for Windows Installer and Setup Squeezer for InstallShield.
As a special benefit for users of the InstallSite web site InstallAware offers a 30% discount on your whole order when you enter the coupon code INSTALLSITEXTRM in the order form at http://www.installaware.com/buy.asp
Setup Squeezer from InstallAware
, Apr 13 2006 16:44
Posted 13 April 2006 - 16:44
Posted 15 December 2006 - 17:32
InstallAware Software Corp. changed their discount offer. The new coupon code is INSTALLSITEORG and the discount rate is 10%.
