Minor Upgrade Problem
tnand53
tnand53
  • 23 posts
Posted 20 February 2014 - 18:17
I have a custom action which i do not want to run on a minor upgrade. What custom actions conditions should i use
I have one more problem . After the minor upgrade is over ; when i double click Setup.exe ; it again does to the "Resume Setup" mode again. After minor upgrade installation is over; it always says install is successful. What could be issue
Edited by tnand53, 20 February 2014 - 18:19.
Posted 20 February 2014 - 21:06
You could use
Not Installed
as condition for a custom action that should only run during first time install.
Did you increment the ProductVersion? I would expect the setup to enter maintenance mode. Check the command line settings in setup.ini. Try to launch the msi directly (without setup.exe) to see what happens.
