Can anyone enlighten me on how will I modify the dialogs in the Installation Designer and control its sequence. I saw many dialogs by default but I don't know how to choose only few. I also want to modify or add a dialog but is it ok to modify an existing one and rename it? If yes is it necessary to reopen it in the Dialog View.
Please help me experts!
Mayee
How to modify dialogs and its sequence?
MayeeKeowee
, Sep 08 2005 09:39
Posted 14 September 2005 - 10:26
Go to Behaviour and Logic > InstallScript. Select your setup.rul. From the left compbo box (above the script) select Defore Data Move. In the right combo box select OnFirtsUIBefore. This will insert the default code of the OnFirtsUIBefore event handler in your script (if it isn't there already). Now yu can edit that script function to specify which dialogs to display.
