Installation on Vista
vishwa
, Feb 01 2007 19:39
Posted 01 February 2007 - 19:39
Hello,
Our product does not support installation on Vista. So, the installation script checks for the WinMajor and WinMinor, and if it is 6.0, the installation aborts.
However, as soon as the installation aborts, the Program Compatibility Assistant starts up and prompts that there was an error during the installation. It asks "Do you want to re-run the program in recommended settings?"
If we choose to re-run, then Vista launches our product installation in a mode that simulates and earlier version of Windows (Windows XP).
Now, the installation thinks that the OS is XP and goes ahead with the installation, which it should not.
When the installation is re-run, I checked for the following to see if I can find out if this is a Vista installation:
- WinMajor.WinMinor return 5.1 indicating XP
- RegDBGetKeyValueEx of HKLM\Software\Microsoft\Windows NT\CurrentVersion returned 5.1 instead of 6.0, indicating XP
- A check for Vista specific DLLs (%winsysdir%\dfe.dll, for example) shows that this DLL does not exist, indicating that this is not Vista
Is there any way of detecting that the OS is Vista, even when re-run by the Program Compatibility Assistant in a simulated environment?
Please help.
Vishwa
Posted 01 February 2007 - 19:45
The compatibility mode is designed extavtly to tricj such checks. But checking for the file version of a system file (user.exe or such) might work.
